How to start the Gcode file via Modbus TCP? ​
Firmware requirements
  • Firmware version: V2.4.0+
  • UFactory version: V2.4.0+
Holding Registers:
  • function code: 0x10
  • registers: 0x40
It will only trigger the Gcode file under the modbus_tcp folder.
Example to start 1 Gcode file ​
Start 1 Gcode file named 00020.
00 01 00 00 00 09 01 10 00 40 00 01 02 00 14
  • 00 01 00 00: fixed
  • 00 09: data length
  • 01: ID, fixed
  • 10: function code
  • 00 40: register address
  • 00 01: trigger 1 Blockly project
  • 02: data length
  • 00 14: Gcode file name
Example to start 2 Gcode files ​
Start 2 Blockly projects named 00001 and 00032.
00 01 00 00 00 0B 01 10 00 40 00 02 04 00 01 00 32
  • 00 0B: data length
  • 01: ID, fixed
  • 10: function code
  • 00 02: trigger 2 Blockly projects
  • 04: data length
  • 00 01: Gcode file named 00001.txt
  • 00 32: Gcode file named 00050.txt
